FAS25xx ports e0a, e0b, e0M, e0P missing with "Invalid PCIe device detected"
Applies to
- FAS25xx
Issue
- Node reboots without accompanying panic message. The following messages can be present before shutting down:
Mon Jul 5 09:13:39 CEST [node_name:netif.hangDetected:warning]: Network interface e0b hung (PCIe RcvMstAdt). Resetting to recover. Driver: igb.
Mon Jul 5 09:22:13 CEST [node_name:netif.hangDetected:warning]: Network interface e0a hung (PCIe RcvMstAdt). Resetting to recover. Driver: igb.
- Node remains up but stops responding on the network via ports e0a, e0b, and e0M.
- From console log (
system log
from SP or boot logs from console connection):
Mar 11 08:10:05 [XXX:pvif.allLinksDown:EMERGENCY]: ifgrp a0a: All links are down
kill: 85241: No such process
Terminated
Uptime: 311d17h23m44s
HALT: HA partner has taken over (ic) on Wed Mar 11 11:54:45 CET 2020
ugen0.2: <Micron Technology> at usbus0 (disconnected)
System rebooting... <==== the system rebooted, but didn't panic
================ Log #1 end time Wed Mar 11 10:54:44 2020
================ Log #2 start time Wed Mar 11 10:55:10 2020
Invalid PCIe device detected below PCIe Root Port(Bus/Dev/Func): 00/1C/00 <== the BIOS is not able to recognize some components
Actual Vendor ID and Device ID:FFFF/FFFF
Expected Vendor ID and Device ID:8086/150E
Mezzanine Card ID(02 - 10GbE, 03 - FC, 07 - No Dev, others - Resv):07
BIOS is resetting system...
- If node can boot, ports e0a, e0b, e0M, and e0P will either be missing entirely, or report
Hardware Initialization Failed
insysconfig
output:
slot 0: Internal 10/100/1000 Ethernet Switch Status: Unknown
slot 0: Quad Gigabit Ethernet Controller 82580
e0a MAC Address: 00:00:00:00:00:00 (Hardware Initialization Failed: IGB: 3)
e0b MAC Address: 00:00:00:00:00:00 (Hardware Initialization Failed: IGB: 3)
e0M MAC Address: 00:00:00:00:00:00 (Hardware Initialization Failed: IGB: 3)
e0P MAC Address: 00:00:00:00:00:00 (Hardware Initialization Failed: IGB: 3)
slot 0: Interconnect HBA: Mellanox IB MT25204
