NetApp Knowledge Base
"Failed Disk Drawer" Drawers Control Module reports "NONCRITICAL, REPORT, PATH FAIL"
2,846
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • DS460C
Issue
  • EMS reports
[node01: dsa_worker5: ds.sas.hostphy.disableErr:alert]: Port [DCM2-2] on channels 9b shelf ID 12 IOM B disabled due to excessive invalid dword error.
[node01: dsa_worker5: callhome.hostport.disable:alert]: Call home for HOST_PORT_FAIL - Disabled by IOM
[node01: monitor: monitor.globalStatus.critical:EMERGENCY]: There are not enough spare disks. Assign unowned disks. Disk shelf fault.
[node01: statd: monitor.shelf.warning:error]: Fault reported on disk storage shelf attached to channel 10a. Check fans, power supplies, disks, and temperature sensors.
[node01: dsa_disc: ses.shelf.drwr.phy.rateunkwn:alert]: Drive shelf "33", module "B", drawer "4", PHY "12" is reporting an unknown link rate.
  • AutoSupport STORAGE-FAULT  shows Drawers Control Module reports "NONCRITICAL, REPORT, PATH FAIL".
Enclosure:
Element Status         Status Bytes  Status Descriptions
  1: OK                01,00,02,00   FAIL
Drawers Control Module:
  1 [IOM12 A]    : NONCRITICAL       03,00,11,00   REPORT, PATH FAIL
  2 [IOM12 A]    : OK                01,00,01,00   REPORT
New to NetApp?
