NetApp Knowledge Base
CriticalFruNotPresentAlert on AFF A400, FAS8300 or FAS8700
1,454
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • AFF A400
  • FAS8300
  • FAS8700
Issue
  • CriticalFruNotPresentAlert reports against a FAN module:
Alert ID: CriticalFruNotPresentAlert:Fan4 is not present in the chassis 01212341211
Node: netapp-01
Monitor: chassis
Alerting Resource: Fan4#123456789000
Subsystem: Environment
Indication Time: Fri SEP 18 23:20:06 2020
Perceived Severity: Critical
Probable Cause: Configuration_error
Description:
Fan4 is not present in the chassis 01212341211. The nodes in this chassis are netapp-01
Corrective Actions:
1. Plug in Fan4 correctly into the slot.
2. Refer to the Hardware specification guide for more information on the position of the field-replaceable unit (FRU)
3. Contact support personnel if the alert persists.
Possible Effect:
The nodes in the chassis might not function effectively or redundancy might be lost.
Acknowledge: false
Suppress: false
Policy: CriticalFruNotPresentAlertPolicy
Acknowledger: -
Suppressor: -
Additional Information: Serial No of the FRU: Fan4#123456789000
  • It is possible that after reporting hm.alert.raised:alert in EMS, it recovers on its own.
[cphmd: hm.alert.raised:alert]: Alert Id = CriticalFruNotPresentAlert , Alerting Resource = Fan1#042247006866 raised by monitor chassis
[cphmd: hm.alert.raised:alert]: Alert Id = CriticalFruNotPresentAlert , Alerting Resource = Fan2#042247006866 raised by monitor chassis
[cphmd: hm.alert.raised:alert]: Alert Id = CriticalFruNotPresentAlert , Alerting Resource = Fan3#042247006866 raised by monitor chassis
[cphmd: hm.alert.raised:alert]: Alert Id = CriticalFruNotPresentAlert , Alerting Resource = Fan4#042247006866 raised by monitor chassis
[cphmd: hm.alert.cleared:notice]: Alert Id = CriticalFruNotPresentAlert , Alerting Resource = Fan1#042247006866 cleared by monitor chassis
[cphmd: hm.alert.cleared:notice]: Alert Id = CriticalFruNotPresentAlert , Alerting Resource = Fan2#042247006866 cleared by monitor chassis
[cphmd: hm.alert.cleared:notice]: Alert Id = CriticalFruNotPresentAlert , Alerting Resource = Fan3#042247006866 cleared by monitor chassis
[cphmd: hm.alert.cleared:notice]: Alert Id = CriticalFruNotPresentAlert , Alerting Resource = Fan4#042247006866 cleared by monitor chassis
  • All Fan sensors show the fan as working correctly except for FRU INFO
Fan4 FRU INFO    discrete    failed
  • BMC sensors show the FRU ID as unreadable
FRU Device Description : Fan4_FRU (ID 8)
Unknown FRU header version 0xff
New to NetApp?
