Controller panic and CNA ports down when connecting to Cisco Nexus Fabric Extender
Applies to
- FAS9000
- FAS8200
- FAS27x0
- FAS26x0
- AFF A200
- AFF A220
- AFF A300
- AFF A700
- ONTAP 9
- Qlogic 8324 CNA
- Cisco Nexus 2348UPQ Fabric Extender (FEX)
- Cisco Nexus N2K-C2232PP-10GE Fabric Extender (FEX)
Issue
- When connecting Qlogic adapters to a Nexus FEX, the storage node panics
PANIC : PCI Error NMI from device(s):RPT(0,3,3):QLogic FC/10GbE CNA on Controller.version: 9.5P15: Tue Nov 17 02:40:18 EST 2020conf : x86_64.optimizecpuid = 4KDB: stack backtrace:vpanic() at vpanic+0x6d9/frame 0xfffffe0258b59c50panic() at panic+0x43/frame 0xfffffe0258b59cb0platform_os2sp_port_present() at platform_os2sp_port_present+0x259/frame 0xfffffe0258b59ce0psl_search_list() at 0xffffffff8213db10/frame 0xfffffe0258b59d20generic_nmi_handler() at generic_nmi_handler+0xe4/frame 0xfffffe0258b59d60trap() at trap+0x7f0/frame 0xfffffe0258b59f20Xnmi() at Xnmi+0xd3/frame 0xfffffe028649e470ql_rdwr_indreg32() at ql_rdwr_indreg32+0xca/frame 0xfffffe028649e4b0ql_minidump() at ql_minidump+0x77a/frame 0xfffffe028649e660ql_del_cdev() at ql_del_cdev+0x85f/frame 0xfffffe028649e800devfs_allocv() at devfs_allocv+0x29dc/frame 0xfffffe028649e850kern_ioctl() at kern_ioctl+0x230/frame 0xfffffe028649e8c0sys_ioctl() at sys_ioctl+0x16c/frame 0xfffffe028649e990amd64_syscall() at amd64_syscall+0x18b/frame 0xfffffe028649eab0Xfast_syscall() at Xfast_syscall+0xfb/frame 0xfffffe028649eab0--- syscall (54, FreeBSD ELF64, sys_ioctl), rip = 0x8004cd23a, rsp = 0x7fffffffea58, rbp = 0x7fffffffeb40 ---PCI Error NMI from device(s):ErrSrcID(CorrSrc(0x2900),UCorrSrc(0)), RPT(0,2,0):QLogic FC/10GbE CNA in slot 2 on Controller.
- After the storage node boots from panic, the CNA ports are stuck in initalizing firmware state
cluster::> run -node node1 sysconfig -v 2
slot 2: Fibre Channel Target Host Adapter 2a
(QLogic CNA 8324 (8362) rev. 2, <INITIALIZING FIRMWARE>)
Firmware rev: 8.9.0
Flash rev: 6.0.1
Host Port Addr: 000000
FC Nodename: 50:0a:09:80:80:72:e6:d6 (500a09808072e6d6)
FC Portname: 50:0a:09:88:80:72:e6:d6 (500a09888072e6d6)
Connection: No link
Switch Port: Unknown
- The connection from switch shows it flapping, not connected, or possible normal.
- This can be triggered when the Cisco switch is upgraded to version 9.3(5) or later.
