NetApp Knowledge Base
Can the e0M and SP/BMC interfaces be configured on different subnets?
7,164
Visibility:
Votes:
6
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • All FAS systems
  • All AFF systems (except AFF A700s and AFF A800)
Answer
The e0M and SP/BMC interfaces should always be in the same subnet when these two interfaces share a single physical port.
  • Logical interfaces (LIFs) configured on the e0M interface, and the SP/BMC network interface, both connect to the external management network by means of an internal network switch to a single physical port (graphically identified as the "wrench" port).
  • IP addresses for both interfaces must be on the same subnet directly reachable via the wrench port
  • Isolate management network traffic
Controllers that have separate, dedicated RJ45 ports for the e0M and BMC interfaces (such as the AFF A700s and the AFF A800) can been configured on different subnets.
Note: Regardless of whether the controller has shared or separate e0M and SP/BMC interfaces, best-practice is that neither interface should be configured within any data subnet. Excessive data traffic can preempt or otherwise interfere with access to the e0M or SP/BMC interface, impairing overall management of the controller.
Additional Information
The e0M interface is dedicated to ONTAP management activities, whereas the SP/BMC interface is dedicated to out-of-band ancillary functions (remote power on/off/status, log collection, etc.).
It is a best practice to configure SP/BMC and the e0M management interface on a subnet dedicated to management traffic. Running data traffic over the management network can cause performance degradation and routing problems.
  • The e0M management interface and the SP/BMC network interface are connected to two ports of the controller's internal switch.
  • A third port of the internal switch is connected to the external Wrench port (RJ45) which allows access from outside.
FAS systems
Note: The e0M and SP/BMC interfaces do not support VLAN tagging and must be connected to an access port. See e0M, Service Processor or BMC unreachable on network due to VLAN tagging on switch port
