NetApp Knowledge Base
CRC errors on a data port connected to a Cisco switch
1,673
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
  • FAS Systems
  • AFF Systems
  • Cisco switch
  • Active IQ Digital Advisor
Issue
  • An Active IQ Risk alert is received:
Risk: This system has a high count of CRC errors accumulated on at least one data network port that should be investigated.
Description: This system has CRC errors on data port e0e.
Impact: High CRC errors counts, or link resets can result in packet loss and are typically caused by physical defects in the port, SFP, or cables
  • The port is connected to a Data Switch
  • IFSTAT-A section of AutoSupport or cluster::> ifstat -a reveals CRC errors:
-- interface  e0e  (1 day, 1 hour, 11 minutes, 41 seconds) --
RECEIVE
Total frames:     6821k | Frames/second:      75  | Total bytes:      6681m
Bytes/second:    73660  | Total errors:      151  | Errors/minute:       0
Total discards:      0  | Discards/minute:     0  | Multi/broadcast:   254k
Non-primary u/c:     0  | CRC errors:        151  | Runt frames:         0
Long frames:         0  | Length errors:       0  | Alignment errors:    0
No buffer:           0  | Pause:               0  | Jumbo:               0
Noproto:             0  | Bus overruns:        0  | LRO segments:      399m
  • SFP is replaced on both sides
  • Cable between node and switch is replaced
  • The stats on the node port are cleared, CRC errors return
::>run -node * ifstat -z e0e
New to NetApp?
