NetApp Knowledge Base
StorageGRID Appliance reports Storage appliance storage connectivity degraded and Fibre channel link errors detected
4,605
Visibility:
Votes:
2
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
  • NetApp StorageGRID Appliances
  • NetApp E-Series
Issue
StorageGRID GRID Manager reports:
There is a problem with one or more connections between the compute controller and storage controller.
  • Major Event Log  on E-Series controller may report the following events:
Fibre channel link errors continue (Event type 1206)
Fibre channel link errors - threshold exceeded (Event type 1207)
Example:
Event type: 1206 / 1207
Event category: Error
Priority: Informational
Event needs attention: false
Description: Fibre channel link errors continue Fibre channel link errors - threshold exceeded
Component location: Host-side: controller in bay B, port 4
Logged by: Controller in bay B
  • STORAGE-ARRAY-PROFILE on E-Series controller may report the Fibre Channel port is Down.
      Host interface:                  Fibre
         Host Interface Card(HIC):     Baseboard
         Channel:                      2
         Port:                         0b
         Current ID:                   126/0x0
         Preferred ID:                 1/0xE8
         NL-Port ID:                   0x000000
         Maximum data rate:            16 Gbps
         Current data rate:            4 Gbps
         Data rate control:            Auto
         Link status:                  Down
  • fcDump in STATE-CAPTURE-DATA on E-Series controller may report an increase in Errors and/or Bad Char:
2806-B           Our  Num  ::...Exchange Counts...:: Num  ..Link Up..
Chip   LinkStat  Port Port ::                     :: Link  Bad  Bad
                  ID  Logi ::Open    Total  Errors:: Down  Char Frame
 2-Src Up-Ptp       2    2 ::  2  106083407      0::    0     0     0
 3-Src Up-Ptp       2    2 ::  0          0   2969::    0  -415122385   0
New to NetApp?
