NetApp Knowledge Base
AutoSupport Message: Chassis Power Degraded
1,326
Visibility:
Votes:
1
Category:
data-ontap-7
Specialty:
7dot
Last Updated:
Applies to
  • Data ONTAP 8.2.5 and earlier
  • Data ONTAP operating in 7-Mode
Issue
CHSPWR:System Notification from Filer1 (CHASSIS POWER DEGRADED: PSU1 12V is  failed. PSU1 5V is  failed. PSU1 3V is  failed)
[Filer1: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU 1 AC Failed
[Filer1: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU 1 12V Failed
[Filer1: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU 1 5V Failed
[Filer1: monitor.chassisPower.degraded:notice]: Chassis power is degraded:
AutoSupport message: Chassis Power Degraded
The following AutoSupport messages are sent:
SHELF_FAULT
CHASSIS POWER SUPPLY FAIL
CHASSIS POWER SUPPLY DEGRADED
CHSPWR:System Notification from Filer1 (CHASSIS POWER DEGRADED:  sensor RTC Battery) WARNING
Troubleshooting:
comprehensive mb test failed
ERROR ENV013858: sensor RTC Battery failed;
                 sensor failed to return to normal
                 measured: 2633mV; upperLimit: 3996mV; lowerLimit: 0mV;
FSE bent clip which holds battery to fasten battery, and ran diagnostics again, this time successfully:
(RTC Battery) ........... 2800< 3072 mV <3500
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
