NetApp HCI Element upgrade using HCC failed
Applies to
- NetApp HCI upgrade using HCC
- Management services 2.15.x or earlier
- NetApp HCI upgrade using staging option
Issue
- The upgrade fails without no progress bar in HCC
- Click on check log
Storage cluster upgrade: Failed : Staging storage node <NODENAME> failed. Try increasing QOS on the NetApp-HCI-storage-service-pakages volume and retry the operation.
Error seen in the mnode docker logs:2020-10-08 23:42:56: Transient API call failure method = Download retry 3/56
2020-10-08 23:58:56: Connection Error: Unable to communicate with {}.
Possible reasons: cluster is experiencing high latency, network communication issues between nodes and management node, or nodes are up but no valid API response received.
Re-run the command after making sure all cluster nodes are up and running and network communication between management node and storage nodes is working.
