How to remove and add a storage node during Element upgrade with sfinstall
Applies to
- NetApp Element software 8.0 and above
- NetApp H-series storage nodes
- NetApp SF-Series storage nodes
- Upgrade using
sfinstallcommand
- NetApp SolidFire Active IQ and cluster UI report an
Upgrade in progressalert - Normal drive and node removal API calls and GUI options are not accepted while cluster is in an upgrade process
- This article explains the recommended procedure for removing a failed storage node during an Element upgrade
