NetApp Knowledge Base
ONTAP System Manager KBs
Featured
New System Manager Global Search
Search the NetApp Support Site and Knowledge Base for answers directly through ONTAP System Manager.
Manage certificates
Learn how to generate, install or renew self-signed and CA signed certificates using ONTAP System Manager.
Delete files or folders
How to delete files and folders using ONTAP System Manager.
Authenticate using a domain account
Configure ONTAP System Manager to use domain authentication.
Manage RBAC for File System Analytics
Manage RBAC for File System Analytics in System Manager.
New UI for System Manager
Navigate the new System Manager UI beginning in ONTAP 9.7 and later.
Other Resources
  • System Manager login very slow but successful, taking 30 to 90 seconds to complete authenticationMon, 06 Apr 2026
  • Can the detection date of suspected file types be identified directly in ONTAP System Manager?Mon, 06 Apr 2026
  • Period on 10 Key numeric pad on full size keyboard not registering decimal input in ONTAP System ManagerFri, 03 Apr 2026
  • SAML authentication in ONTAP via Entra ID fails with unexpected EOF while readingWed, 01 Apr 2026
  • Cannot access System Manager from one nodeMon, 16 Mar 2026
  • System Manager webui stuck at login after updating SSL certificateSat, 14 Mar 2026
  • System Manager display causing eye pain and vertigoThu, 12 Mar 2026
  • Is the SVM location change in ONTAP 9.17 a UI update or a functional change?Fri, 06 Mar 2026
  • ONTAP System Manager GUI shows inconsistency in serving data for CVOThu, 05 Mar 2026
  • Volume Fractional Reserve Settings on NetApp ASA-R2 SystemsMon, 02 Feb 2026
  • System manager shows an incorrect view of support casesFri, 30 Jan 2026
  • How to create a custom role with full volume-operation privileges in System ManagerFri, 30 Jan 2026
  • DNS servers for SVM added via System Manager are not appliedTue, 27 Jan 2026
  • What is the default value for Superuser Security Types when creating export policy while create volume with System Manager?Tue, 27 Jan 2026
  • Which severity level of EMS events is displayed as error on Health in System Manager?Thu, 22 Jan 2026
  • OSM  Fails to Upload Image with Processing package failedWed, 21 Jan 2026
  • Snapshot creation from cinder to ONTAP fails multiple timesTue, 13 Jan 2026
  • What do the IOPS, latency, and throughput values displayed in the Performance pane of ONTAP System Manager represent mean?Fri, 09 Jan 2026
  • Unable to modify approval group of existing multi-admin approval with System ManagerTue, 06 Jan 2026
  • Is it possible to receive an email when an ONTAP event is resolved?Mon, 05 Jan 2026
  • Can be FlexVol volume historical capacity usage checked in System Manager?Fri, 24 Apr 2026
  • System Manager Internal Server error when trying to acknowledge AIQDA suggestionsFri, 24 Apr 2026
  • ONTAP System Manager displays unused ports as downFri, 17 Apr 2026
  • ONTAP System Manager is not reachable after certificate changesThu, 16 Apr 2026
  • What is Timezone Database in System Manager starting ONTAP 9.13.1Mon, 13 Apr 2026
  • Unable to login to System Manager "ERR_SSL_VERSION_OR_CIPHER_MISMATCH"Mon, 13 Apr 2026
  • Upgrade Advisor fails to generate upgrade plan in Active IQ Digital AdvisorMon, 13 Apr 2026
  • System Manager disk rekey alertMon, 13 Apr 2026
  • System Manager display causing eye pain and vertigoThu, 09 Apr 2026
  • How to install or renew a CA signed certificate using ONTAP System ManagerThu, 09 Apr 2026
  • Can the detection date of suspected file types be identified directly in ONTAP System Manager?Tue, 07 Apr 2026
  • System Manager Automatic Update is enabled but firmware is not updatingWed, 25 Mar 2026
  • ONTAP System Manager reports SAML error "Message rejected, was issued in the future"Tue, 24 Mar 2026
  • Can System Manager be configured to use MFA (MultiFactor Authentication)?Fri, 20 Mar 2026
  • How to create a custom role and user for ONTAP System Manager in ONTAP 9.7 and laterWed, 18 Mar 2026
