NetApp Knowledge Base
Node shutdown with "monitor.shutdown.brokenDisk:EMERGENCY" error
3,945
Visibility:
Votes:
2
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • ONTAP version earlier than 9.12.1
  • FAS / AFF models
Issue
monitor.shutdown.brokenDisk message occurs when the automatic shutdown sequence expires per callhome.shutdown.pending (the RAID group was in a degraded mode for the time interval specified. The default is usually 24 hours)
  • Node shuts down with the following error and without performing a takeover:
Example:
[node01: statd: monitor.brokenDisk.notice:info]: When two disks are broken in raid_dp volume, the system shuts down automatically every 24 hours to encourage you to replace the disk. If you reboot the system it will run for another 24 hours before shutting down. (The 24 hour timeout may be increased by altering the "raid.timeout" value using the "options" command.)
[node01: statd: monitor.shutdown.brokenDisk:EMERGENCY]: data disk,parity disk in RAID group "/aggr0_n1/plex0/rg0" are broken. Halting system now.
[node01: shutdown_thread0: ha.localNodeShutDown:notice]: Shutdown of the local node has been initiated with inhibit_takeover set to TRUE.
[node01: shutdown_thread0: kern.shutdown:notice]: System shut down because : "BROKEN DISK".
::> cluster ring show
Node      UnitName Epoch    DB Epoch DB Trnxs Master    Online
node01    mgmt     0        2        13923732 -         offline
node01    vldb     0        2        556665   -         offline
node01    vifmgr   0        2        56       -         offline
node01    bcomd    0        2        11       -         offline
node01    crs      0        2        1        -         offline
::> storage failover show
                              Takeover
Node           Partner        Possible State Description
node01         node02         false    Waiting for node02, Takeover is not
                                       possible: Partner node halted after
                                       disabling takeover
node02         node01         -        Unknown
  • Two disks failed from the same RAID-DP group and the RAID group is in a "double degraded" state:
Example:
Aggregate aggr0_n1 (online, raid_dp, degraded) (block checksums)
  Plex /aggr0_n1/plex0 (online, normal, active, pool0)
    RAID group /aggr0_n1/plex0/rg0 (double degraded, block checksums)
RAID Disk      Device      HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
dparity        0d.03.0     0d    3   0   SA:A   0   SAS 10000 1142352/2339537408 1144641/2344225968
parity         FAILED              N/A                        1142352/ -
data           FAILED              N/A                        1142352/ -
New to NetApp?
