NetApp Knowledge Base
System Manager shows flexgroup balance as low
1,142
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9.12.1
  • System Manager
  • FlexGroups
Issue
  • System Manager shows the FlexGroup balance as low.  After running a rebalance System Manager still reports the FG balance is low.
  • From the CLI we can see most of the members are between 45% and 50% used.   Member volume flexgroup__0012 is at 62% capacity and thus the "low status" in System Manager.
  • Overall the FG is balanced.  One member volume is imbalanced.  The FlexGroup Balance Status in System Manager is based on the max constituent imbalance not the overall FlexGroup imbalance percent.
::*> vol show -volume flexgroup*
Vserver   Volume       Aggregate    State      Type       Size  Available Used%
svm1 flexgroup   -            online     RW      34.07TB    16.25TB   49%
svm1 flexgroup__0001 aggr1_node2 online RW 1.95TB 1.02TB  45%
svm1 flexgroup__0002 aggr1_node1 online RW 2.07TB 1.02TB  48%
svm1 flexgroup__0003 aggr1_node1 online RW 2.00TB 1.02TB  46%
svm1 flexgroup__0004 aggr1_node2 online RW 2.14TB 1.01TB  50%
svm1 flexgroup__0005 aggr1_node1 online RW 2.16TB 1.02TB  50%
svm1 flexgroup__0006 aggr1_node2 online RW 2.12TB 1.01TB  49%
svm1 flexgroup__0007 aggr1_node2 online RW 2.06TB 1.02TB  48%
svm1 flexgroup__0008 aggr1_node2 online RW 2.14TB 1.02TB  50%
svm1 flexgroup__0009 aggr1_node1 online RW 2.03TB 1.02TB  47%
svm1 flexgroup__0010 aggr1_node1 online RW 1.94TB 1.02TB  44%
svm1 flexgroup__0011 aggr1_node1 online RW 2.16TB 1.01TB  50%
svm1 flexgroup__0012 aggr1_node2 online RW 2.81TB 1.02TB  62%
svm1 flexgroup__0013 aggr1_node2 online RW 2.03TB 1.02TB  47%
svm1 flexgroup__0014 aggr1_node1 online RW 2.20TB 1.02TB  51%
svm1 flexgroup__0015 aggr1_node1 online RW 2.17TB 1.02TB  50%
svm1 flexgroup__0016 aggr1_node2 online RW 2.08TB 1.02TB  48%
Cluster::*> volume rebalance show
Vserver: svm1
                                         Used      Size
                                          For   Used by  Target     Imbalance
Volume      State             Total Imbalance Snapshots    Used    Size      %
FG       not-running     34.09TB   14.47TB   1.59TB        -  989.1GB    6%
FG__0001 not-running      1.95TB   747.4GB  98.32GB  925.9GB -178.6GB  -19%
FG__0002 not-running      2.07TB   944.2GB  29.16GB  925.9GB  18.25GB    1%
FG__0003 not-running      2.00TB   753.5GB  153.3GB  925.9GB -172.4GB  -18%
FG__0004 not-running      2.14TB    1015GB  23.22GB  925.9GB  89.26GB    9%
FG__0005 not-running      2.16TB    1010GB  47.90GB  925.9GB  84.25GB    9%
FG__0006 not-running      2.11TB   841.8GB  173.6GB  925.9GB  -84.2GB   -9%
FG__0007 not-running      2.06TB   914.6GB  45.15GB  925.9GB  -11.4GB   -1%
FG__0008 not-running      2.14TB   973.8GB  67.26GB  925.9GB  47.85GB    5%
FG__0009 not-running      2.03TB   741.5GB  194.5GB  925.9GB -184.5GB  -19%
FG__0010 not-running      1.95TB   777.3GB  68.98GB  925.9GB -148.6GB  -16%
FG__0011 not-running      2.15TB   885.0GB  168.5GB  925.9GB  -40.9GB   -4%
FG__0012 not-running      2.81TB    1.47TB  177.6GB  925.9GB  576.1GB   62%
FG__0013 not-running      2.04TB   757.4GB  179.2GB  925.9GB -168.6GB  -18%
FG__0014 not-running      2.20TB   951.5GB  149.1GB  925.9GB  25.52GB    2%
FG__0015 not-running      2.17TB    1.02TB  21.41GB  925.9GB  121.6GB   13%
FG__0016 not-running      2.08TB   952.2GB  30.36GB  925.9GB  26.23GB    2%
17 entries were displayed.
  • No errors and last rebalance completed on the FlexGroup and the most utilized FlexGroup member.
Cluster::*> volume rebalance show -instance
                                     Vserver Name: svm1
                                      Volume Name: FG
                                   Is Constituent: false
                                  Rebalance State: not-running
                        Rebalance Notice Messages: -
                             Rebalance Start Time: Thu Dec 15 08:15:15 2022
                              Rebalance Stop Time: Sat Dec 17 08:15:15 2022
                                Rebalance Runtime: 48h0m0s
                        Rebalance Maximum Runtime: 48h0m0s
                  Most Recent File Move Timestamp: Thu Dec 15 18:21:06 2022
                               File Moves Started: 1
                   Last File Move Error Timestamp: -
                     Last File Move Error File ID: -
Last File Move Error Destination Constituent DSID: -
                        Last File Move Error Code: -
 Vserver Name: svm1
                                      Volume Name: FG__0012
                                   Is Constituent: true
New to NetApp?
