NetApp Knowledge Base
How to collect a Perfstat from clustered Data ONTAP systems using the Perfstat GUI
33,231
Visibility:
Votes:
3
Category:
data-ontap-8
Specialty:
perf
Last Updated:
Applies to
ONTAP 8.3 or later
  • Perfstat is a performance and statistics data collection tool that helps in troubleshooting issues relating to storage system performance.
  • This document provides information about the Perfstat 8.4 GUI tool and the procedure that should be followed to collect performance data using the tool.
  • Please follow these best practices before starting:
  1. Perfstat 8 is for clustered Data ONTAP only.
NOTE:
  • Do not use it with 7-Mode systems.
  • For 7-Mode systems, see KB for Windows and KB for Linux.
  1. Run Perfstat from a physical host or a VM not associated with the cluster being collected against.
  2. Do not attempt to use over a VPN connection, Perfstat is latency-sensitive and will timeout.
  3. Collection host should be on the same network as the cluster, avoid a lot of network hops or latency between host and cluster.
  4. The Perfstat application and related output files should only be stored on the local disk of the collection host.
New to NetApp?
