NetApp Knowledge Base
Why does Auto Giveback become true automatically after chassis replacement?
787
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
ONTAP 9
Answer
  • Enabling the HA configuration command "cluster ha modify -configured true" is described in the Chassis Replacement Guide.
  • If the HA setting is true, "auto givaback" and "storage failover" are automatically enabled.
Additional Information
The warning of command cluster ha modify -configured true indicates the change for the auto giveback is required.
::*> cluster ha modify -configured true
Warning: High Availability (HA) configuration for cluster services requires
         that both SFO storage failover and SFO auto-giveback be enabled. These
         actions will be performed if necessary.
Do you want to continue? {y|n}:
