NetApp Knowledge Base
What to consider regarding compatibility after controller to shelf conversion?
171
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS / AFF
  • ONTAP 9
Answer
  • Check if the resulting shelf is compatible with the existing storage systems
  • When using mixed IOM6 and IOM12 modules in extended shelves, you cannot switch between IOM6 and IOM12 shelves more than once within the same stack
