NetApp Knowledge Base
The Flash Cache NVMe module fault LED on without any error in the module
304
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • Flash Cache NVMe
  • FAS9000
  • AFF-A700
Issue
  • The Flash Cache NVMe module fault LED is on, But the module state is normal.
>sysconfig-a
slot 6-1: Flash Cache NVMe
Serial Number: 7777700xxxxx
Part Number: 119-00207
Hardware Revision: A1
Firmware Version: NA05
Model Name: X9170A
Capacity: 1024 GB
State: ok
STORAGE-FAULT
No faults found in storage subsystem
  • In the SP-LATEST-RUNTIME log, ID 39 LED  is on.
SP-LATEST-RUNTIME
FRU LED ID 38 = LOCATE LED
FRU LED ID 39 = SFM61 FAULT LED
FRU LED ID 38 is off
FRU LED ID 39 is on
New to NetApp?
