NetApp Knowledge Base
Takeover is not possible local partner missing disks after power outage
82
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
FAS8300
Issue
  • After power outage, node reports Takeover is not possible local partner missing disks
  • sysconfig -a on partner node shows startup failed for drives of a specific shelf
15.0 :                                  0.0GB 0B/sect (Startup failed.)
15.1 :                                  0.0GB 0B/sect (Startup failed.)
15.2 :                                  0.0GB 0B/sect (Startup failed.)
15.20:                                  0.0GB 0B/sect (Startup failed.)
15.21:                                  0.0GB 0B/sect (Startup failed.)
15.22:                                  0.0GB 0B/sect (Startup failed.)
15.23:                                  0.0GB 0B/sect (Startup failed.)
  • Same disks appear healthy in sysconfig -a of the partner node
New to NetApp?
