NetApp Knowledge Base
System does not boot due to "Initialization of network interface e0a/e0b failed"
394
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8300
    • Ethernet ports e0a,e0b
    • 10G/25G Ethernet Controller CX5
    • Firmware Version: 16.26.4012
  • ONTAP 9
Issue
  • Takeover is initiated due to no heartbeat detected from partner
Sun Feb 06 11:10:20 +0100 [Node-01: cf_main: cf.fsm.takeoverByPartnerDisabled:error]: Failover monitor: takeover of Node-01 by Node-02 disabled (HA interconnect error. Verify that the partner node is running and that the HA interconnect cabling is correct, if applicable. For further assistance, contact technical support).
Sun Feb 06 11:10:23 +0100 [Node-01: cf_main: cf.fsm.partnerNotResponding:notice]: Failover monitor: partner not responding
Sun Feb 06 11:10:23 +0100 [Node-01: cf_main: cf.fsm.takeoverCountdown:info]: Failover monitor: takeover scheduled in 10 seconds
Sun Feb 06 11:10:33 +0100 [Node-01: cf_main: cf.fsm.takeover.noHeartbeat:alert]: Failover monitor: Takeover initiated after no heartbeat was detected from the partner node.
  • During ANDU the node may fail to boot to waiting for giveback state and keep reporting the following event at console:
Waiting for reservations to clear
  • When attempting to boot the down node following types of messages are observed
Feb 08 11:10:25 [Node-02:netif.init.failed:ALERT]: Initialization of network interface e0a failed due to unexpected software error mlx5_core err=0xfffffff0:0.
Feb 08 11:12:25 [Node-02:netif.init.failed:ALERT]: Initialization of network interface e0b failed due to unexpected software error mlx5_core err=0xfffffff0:0
  • The output of storage failover show displays following status
Cluster::> storage failover show
                              Takeover
Node           Partner        Possible State Description
Node-01
               Node-02        false    In takeover
Node-02
               Node-01        -        Waiting for reservations to clear
2 entries were displayed.
  • SYSCONFIG -V at maintenance mode show that he HA Interconnect ports are both down or missing.
	slot 0: 10G/25G Ethernet Controller CX5
		e0a MAC Address:    XX:XX:XX:XX:XX:XX (auto-unknown-fd-down)
		    SFP Vendor:         Amphenol
		    SFP Part Number:    NDCCGF-N103
		    SFP Serial Number:  XXXXXXXXXXXXXX
		e0b MAC Address:    XX:XX:XX:XX:XX:XX (auto-unknown-fd-down)
		Device Type:        CX5 PSID(NAP0000000006)
  • Reseating the motherboard of the node temporarily recovers the ports
  • Power-cycling the node through the Baseboard Management Controller (BMC) temporarily recovers the ports
New to NetApp?
