NetApp Knowledge Base
Reconstruction does not start after disk replacement using ADP
2,699
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • Advanced Disk Partitioning (ADP)
Issue
  • The disk has failed, so replace the new disk, but not recognize.
  • The RAID group "n1_aggr1" has degraded and neither the existing spare disks in pool0 nor the new disk cannot reconstruct.
Example of node-2 sysconfig -r:
Aggregate n1_aggr1 (online, raid_dp, degraded) (block checksums)
      Plex /n1_aggr1/plex0 (online, normal, active, pool0)
        RAID group /n1_aggr1/plex0/rg0 (degraded, block checksums)
      RAID Disk    Device      HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
      dparity     0a.00.0P1    0a    0   0   SA:B   0  FSAS  7200 3660678/7497068544 3660686/7497084928
      parity      0a.00.1P1    0a    0   1   SA:B   0  FSAS  7200 3660678/7497068544 3660686/7497084928
      data        0a.00.2P1    0a    0   2   SA:B   0  FSAS  7200 3660678/7497068544 3660686/7497084928
      data        0a.00.3P1    0a    0   3   SA:B   0  FSAS  7200 3660678/7497068544 3660686/7497084928
      data        FAILED       N/A                                3660678/ -
      data        0a.00.5P1    0a    0   5 SA:B   0  FSAS  7200 3660678/7497068544 3660686/7497084928
      data        0a.00.6P1    0a    0   6   SA:B   0  FSAS  7200 3660678/7497068544 3660686/7497084928
      data        0a.00.7P1    0a    0   7   SA:B   0  FSAS  7200 3660678/7497068544 3660686/7497084928
      data        0a.00.8P1    0a    0   8   SA:B   0  FSAS  7200 3660678/7497068544 3660686/7497084928
      data      0a.00.9P1    0a    0   9   SA:B   0  FSAS  7200 3660678/7497068544 3660686/7497084928
    Aggregate n2_aggr1 (online, raid_dp) (block checksums)
    Plex /n2_aggr1/plex0 (online, normal, active, pool0)
        RAID group /n2_aggr1/plex0/rg0 (normal, block checksums)
      dparity     0b.10.0     0b    10  0   SA:A   0   SAS 10000 1142352/2339537408 1144641/2344225968
      parity      0b.10.1     0b    10  1   SA:A   0   SAS 10000 1142352/2339537408 1144641/2344225968
      data     0b.10.2     0b    10  2   SA:A   0   SAS 10000 1142352/2339537408 1144641/2344225968
      data        0b.10.3     0b    10  3   SA:A   0  SAS 10000 1142352/2339537408 1144641/2344225968
      data        0b.10.4     0b    10  4   SA:A   0   SAS 10000 1142352/2339537408 1144641/2344225968
      data        0b.10.5     0b    10  5   SA:A   0   SAS 10000 1142352/2339537408 1144641/2344225968
      data     0b.10.6     0b    10  6   SA:A   0   SAS 10000 1142352/2339537408 1144641/2344225968
      data        0b.10.7     0b
 10  7   SA:A   0   SAS 10000 1142352/2339537408 1144641/2344225968
      data        0b.10.8     0b    10  8   SA:A   0   SAS 10000 1142352/2339537408 1144641/2344225968
      data        0b.10.9     0b    10  9   SA:A   0   SAS 10000 1142352/2339537408 1144641/2344225968
    Aggregate n2_aggr0 (online, raid_dp) (block checksums)
      Plex /n2_aggr0/plex0 (online, normal, active, pool0)
        RAID group /n2_aggr0/plex0/rg0 (normal, block checksums)
  dparity     0a.00.0P2    0a    0   0   SA:B   0  FSAS  7200 147102/301265408  147110/301281792
      parity      0a.00.2P2    0a    0   2 SA:B   0  FSAS  7200 147102/301265408  147110/301281792
      data        0a.00.10P2    0a    0   10  SA:B   0  FSAS  7200 147102/301265408  147110/301281792
      data        0a.00.6P2    0a    0   6   SA:B   0  FSAS  7200 147102/301265408  147110/301281792
   data        0a.00.8P2    0a    0   8   SA:B   0  FSAS  7200 147102/301265408  147110/301281792
    Pool1 spare disks (empty)
 Pool0 spare disks
    Spare disks for block checksum
    spare       0b.10.10    0b 10  10  SA:A   0   SAS 10000 1142352/2339537408 1144641/2344225968
    spare       0b.10.11    0b    10  11  SA:A   0   SAS 10000 1142352/2339537408 1144641/2344225968
    spare       0b.00.4P2    0b    0   4   SA:A   0  FSAS  7200 147102/301265408  147110/301281792
  • "n1_aggr1" are configured partition P1 disks, so moving the partition P1 disks from partner node-1, but reconstruction still doesn't start.
      data
      data        0b.10.7     0b    10  7   SA:A   0   SAS 10000 1142352/2339537408 1144641/2344225968
    Pool0 spare disks
    spare       0a.00.4P2    0a    0   4   SA:B   0  FSAS  7200 147102/301265408  147110/301281792
    spare       0a.00.4P1    0a    0   4   SA:B   0  FSAS  7200 3660678/7497068544 3660686/7497084928
    spare       0a.00.10P1    0a    0   10  SA:B   0  FSAS  7200 3660678/7497068544 3660686/7497084928
    spare       0a.00.11P1    0a   0   11  SA:B   0  FSAS  7200 3660678/7497068544 3660686/7497084928
New to NetApp?
