NetApp Knowledge Base
PSU status remains OK after power cable removal
248
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • NetApp AFF A400
  • ONTAP 9
  • power supply unit (PSU)
  • Field Replaceable Unit (FRU)
Issue
  • After removing the power cable from the PSU, the system controller fru show command continues to display the PSU status as OK instead of degraded.
::> system controller fru show
Node               FRU Name                     Subsystem          Status
node-01      Fan2                         Environment        ok
node-01      Fan4                         Environment        ok
node-01      Fan3                         Environment        ok
node-01      Fan1                         Environment        ok
node-01      PSU2                         Environment        ok
node-01      PSU1                         Environment        ok
  • The status does not change even after waiting for 40 minutes.
New to NetApp?
