NetApp Knowledge Base
Multiple disks in different shelves LED light amber
467
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8020
  • DS2246
Issue
  • Multiple disks in different shelves LED light amber.
  • All disks are normal without errors from command: storage show fault -v.
  • Shelf cabling is not correct.
Example:
Controller 1:
Expanders on channel 0a:
Level    1: WWN , ID  0, Serial Number ' ', Product 'DS224IOM6       ', Rev '0191', Slot A
Level    2: WWN , ID  1, Serial Number ' ', Product 'DS224IOM6       ', Rev '0191', Slot A
Level    3: WWN , ID  2, Serial Number ' ', Product 'DS424IOM6       ', Rev '0191', Slot A
Expanders on channel 0b:
Level    1: WWN , ID  2, Serial Number ' ', Product 'DS424IOM6       ', Rev '0191', Slot A
Level    3: WWN , ID  0, Serial Number ' ', Product 'DS224IOM6       ', Rev '0191', Slot A
Controller 2:
Level    1: WWN , ID  0, Serial Number ' ', Product 'DS224IOM6       ', Rev '0191', Slot B
Level    2: WWN , ID  1, Serial Number ' ', Product 'DS224IOM6       ', Rev '0191', Slot B
Level    3: WWN , ID  2, Serial Number ' ', Product 'DS424IOM6       ', Rev '0191', Slot B
Level    1: WWN , ID  2, Serial Number ' ', Product 'DS424IOM6       ', Rev '0191', Slot B
Level    3: WWN , ID  0, Serial Number ' ', Product 'DS224IOM6       ', Rev '0191', Slot B
New to NetApp?
