NetApp Knowledge Base
Multiple Chassis Fan Failures on system with internal fans
685
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
AFF A800
Issue
  • Node is down due to multiple fan failures:
Feb 13 19:17:41 localhost IPMIMain[1258]: [1258 : 1454 CRITICAL][apollo/fan_sensor.c:236]get_fan_speed: Failed! F# = 1; RPM=0
[?] Thu Feb 13 19:12:56 +0000 [node01: env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: Fan9 (0 RPM)
[?] Thu Feb 13 19:13:26 +0000 [node01: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Fan9
[?] Thu Feb 13 19:13:35 +0000 [node01: env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: Fan1 (192 RPM)
[?] Thu Feb 13 19:13:36 +0000 [node01: env_mgr: monitor.chassisFanFail.xMinShutdown:EMERGENCY]: Multiple Chassis Fan failure: System will shut down in 2 minutes.
[?] Thu Feb 13 19:13:57 +0000 [node01: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Fan1
[?] Thu Feb 13 19:14:00 +0000 [node01: monitor: monitor.globalStatus.critical:EMERGENCY]: Multiple fans has failed: Fan9 State, Fan1 State.
[?] Thu Feb 13 19:14:26 +0000 [node01: env_mgr: callhome.c.fan.fru.shut:error]: Call home for MULTIPLE CHASSIS FAN FAILED: System will shut down in 2 minutes
[?] Thu Feb 13 19:15:56 +0000 [node01: env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Multiple fans failed)
New to NetApp?
