NetApp Knowledge Base
Increased Fan Noise from Chassis with Non-Spinning Power Supply Fans
107
Visibility:
Votes:
0
Category:
not set
Specialty:
HW
Last Updated:
Applies to
  • FAS8300
  • ONTAP 9.11.1
  • BMC 13.10P1
  • PSU fan
Issue
Noticed an increase in fan noise, characterized by a louder and higher pitch than usual, coming from the chassis and all four power supply fans are not spinning.
  • Increased Fan Noise: The noise is louder and has a higher pitch than usual, indicating the chassis fans are working harder
  • Non-Spinning Power Supply Fans: All four power supply fans are not spinning
  • No Relevant Event Log Entries: The event log does not report any errors or issues
    • Check command
      • ::> system node run -node * -command storage show fault
      • ::> system controller environment show
New to NetApp?
