NetApp Knowledge Base
Node shutdown with no console. Unable to power on with fans/PSUs reported absent on AFF A400, FAS8300, FAS8700
860
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • ONTAP 9
  • AFF A400 / FAS8300 / FAS8700
Issue
  • Node shuts down/is taken over by partner
  • Connection through BMC indicates host power is off and attempting to power on does nothing (node remains powered down)
  • Console connection shows no output but allows CTRL-G to get to BMC
  • BMC logs indicate repeated voltage errors:
1 | 07/21/2022 | 07:04:26 | Voltage #0x5a | Lower Non-critical going low
2 | 07/21/2022 | 07:04:26 | Voltage #0x5b | Lower Non-critical going low
3 | 07/21/2022 | 07:04:26 | Current #0x5c | Lower Non-critical going low
4 | 07/21/2022 | 07:04:26 | Current #0x5d | Lower Non-critical going low
5 | 07/21/2022 | 07:04:26 | OEM #0x5e | Lower Non-critical going low
6 | 07/21/2022 | 07:04:26 | OEM #0x5f | Lower Non-critical going low
7 | 07/21/2022 | 07:04:26 | Temperature #0x61 | Lower Non-critical going low
8 | 07/21/2022 | 07:04:26 | Fan #0x63 | Lower Non-critical going low
  • This is followed by entities going missing and fans/PSU absent, resulting in shutdown:
108 | 07/20/2022 | 20:04:50 | Entity Presence #0x97 | Absent | Asserted
109 | 07/20/2022 | 20:04:50 | Entity Presence #0x99 | Absent | Asserted
118 | 07/21/2022 | 02:30:13 | Power Unit #0xb6 | | Asserted | absent FRU: MID1_FRU MID2_FRU PSU1_FRU PSU2_FRU FANMODULE1_FRU FANMODULE2_FRU FANMODULE3_FRU
119 | 07/21/2022 | 02:30:13 | Power Unit #0xb7 | | Asserted | absent FRU: MID1_FRU MID2_FRU PSU1_FRU PSU2_FRU FANMODULE1_FRU FANMODULE2_FRU FANMODULE3_FRU
New to NetApp?
