NetApp Knowledge Base
System fault LED is ON and CPU0_Error reports Asserted due to possible motherboard failure
547
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • FAS8200
  • AFF A300
Issue
  • Node's attention LED is ON
  • ONTAP command system node environment sensors show shows:
Node Sensor                 State Value/Units Crit-Low Warn-Low Warn-Hi Crit-Hi
NTAP1-01
     CPU0 Error             fault
                                        ERROR
     Attention              fault
                                       ASSERT
  • Service Processor logs show (note that the errors may be on controller-a or controller-b):
[IPMI.notice]: c001 | 02 | EVT: 0301ffff | CPU0_Error | Assertion Event, "State Asserted"
tag  origin  fld                                     fault reason                                    count  time
1    0x5     /chassis-1/controller-b                 Temperature Sensor 6 Fault                      1      Mon Oct  6
Fault Lights On:
             /chassis-1        1
             /chassis-1/controller-b        1
New to NetApp?
