FAS8200 not boot up after power maintenance with SP error
Applies to
FAS8200
Issue
- FAS8200 cannot boot up with SP error logs below after power maintenance:
Jan 1 00:00:47 (none) : [381 WARNING][hal_api.c:407]hal_api.c : error finding sensor 200 device table entry
Jan 1 00:02:40 (none) hsam[347]: [347 CRITICAL][semaph.c:331]semtimedop error
Jan 1 00:13:36 (none) oem_ipmi: [1858 WARNING][libbattery.c:488]Read from ChargeOption Register failed
Jan 1 00:13:36 (none) oem_ipmi: [1858 WARNING][libbattery.c:488]Read from ChargeCurrent Register failed
Jan 1 00:13:36 (none) oem_ipmi: [1858 WARNING][libbattery.c:488]Read from ChargeVoltage Register failed
Jan 1 00:13:36 (none) oem_ipmi: [1858 WARNING][libbattery.c:488]Read from ChargeInCurrent Register failed
Jan 1 00:13:36 (none) oem_ipmi: [1858 WARNING][libbattery.c:488]Read from ChargeManufID Register failed
Jan 1 00:13:36 (none) oem_ipmi: [1858 WARNING][libbattery.c:488]Read from ChargeDevID Register failed
Jan 1 00:13:37 (none) scratchpad: [1886 WARNING][scratchpad.c:588]Header signature mismatch found on BIOS region.
Jan 1 00:13:37 (none) scratchpad: [1886 WARNING][scratchpad.c:742]Decoding region 1 failed
Jan 1 00:13:37 (none) scratchpad: [1886 WARNING][scratchpad.c:588]Header signature mismatch found on ONTAP region.
Jan 1 00:13:37 (none) scratchpad: [1886 WARNING][scratchpad.c:756]Decoding region 2 failed- Power cycle or reseat controller does no help.
