NetApp Knowledge Base
FAS8060: Environmental Reason Shutdown (Battery PCT capacity critical)
554
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8060
  • Service processor firmware 3.0.1P3 or earlier
Issue
The node just replaced motherboard suddenly shutdown and console log indicates below message.
Tue Dec 15 19:08:48 KST [Nodename:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery PCT capacity critical)
Uptime: 8m18s
The "system sensors" command displays "na":
SP> system sensors filter Bat_Initial_Fcc
Sensor Name      | Current    | Unit       | Status     | LCR       | LNC       | UNC       | UCR
Bat_Initial_Fcc  | na      | Amps * hour | ok         | na        | na        | na        | na
New to NetApp?
