NetApp Knowledge Base
FAS2720 boots failed with nvmem.battery.notPresent
584
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • FAS2720
  • FAS2750
Issue
  • Node boots with error below, and shuts down after 5 minutes.
WARNING:  The battery is experiencing a critical failure:
- Failed to detect the battery learning status
Without a working battery, the system cannot retain data
during a power outage, which can result in data loss.
Power down the system and verify that the battery is
properly installed.
To ignore this failure and boot the system in a mode
where data loss might occur, press 'c' followed by 'Enter'
[callhome.battery.failure:EMERGENCY]: Call home for BATTERY (not present) CRITICAL.
[nvmem.battery.notPresent:ALERT]: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.
  • Regarding the NVMEM battery data, we noted the following:
During charging:
Remaining Capacity: 1495 mAh
Full Charge Capacity: 1511 mAh
Relative Charge: 99%
Absolute Charge: 72%
After charging:
Remaining Capacity: 1041 mAh
Full Charge Capacity: 1041 mAh
Relative Charge: 100%
Absolute Charge: 50%
New to NetApp?
