NetApp Knowledge Base
Environmental Reason Shutdown (Battery current critical)
1,342
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • AFF A400, AFF C400
  • ASA A400,ASA C400
  • FAS8300, FAS8700
  • BMC 13.x
Issue
The FAS8300 node experienced frequent shutdowns. The system console logs showed the following errors:
Jun 12 07:51:01 [N2:nvmem.battery.currentHigh:EMERGENCY]: The NVMEM battery current is critically high (2450mA). To prevent data loss, the system will shutdown in 5 minutes.
Jun 12 13:01:11 [N2:nvmem.battery.currentHigh:EMERGENCY]: The NVMEM battery current is critically high (2225mA). To prevent data loss, the system will shutdown in 5 minutes.
Jun 25 09:50:39 [N2:nvmem.battery.currentHigh:EMERGENCY]: The NVMEM battery current is critically high (1725mA). To prevent data loss, the system will shutdown in 5 minutes.
Jun 25 09:55:38 [N2:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery current critical)
New to NetApp?
