NetApp Knowledge Base
Correctable memory errors reporting in ONTAP versions with static thresholds
1,409
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
ONTAP versions:
  • 9.4P5 and earlier P releases
  • 9.3P10 and earlier P releases
  • 9.2 all P releases
  • 9.1P17 and earlier P releases
Platforms:
  • AFF systems
  • ASA systems
  • FAS systems
Note: For all other ONTAP versions see: How to troubleshoot correctable memory errors on FAS and AFF systems
Issue
  • Node is reporting correctable ECC errors:
event log show -event *cecc*
Sun Nov 11 08:00:52 GMT [ClusterA-01: idle_thread0: cecc_log_summary_1:warning]: params: {'total_num_ceccs': '56', 'num_ceccs': '3'}
Sun Nov 11 08:18:40 CST [cecc_log.summary:warning]: Total of 303 new correctable ECC errors just reported. You might want to check system memory. 12828 correctable ECC errors reported since booting.
  • show-memory-errors is reporting multiple CECC errors on the same DIMM
ClusterA::*> set advanced
ClusterA::*> system node show-memory-errors
Correctable ECC Memory Errors:
Node: ClusterA-01
DIMM      CECC  Multiple Err
Name     Count  Same Address
DIMM-1       0   false
DIMM-2       22  false
DIMM-3       0   false
Node: ClusterA-02
DIMM-1       0  false
DIMM-2       0  false
DIMM-3       0  false
6 entries were displayed.
  • AutoSupport alert may be triggered
CriticalCECCCountMemErrAlert
New to NetApp?
