NetApp Knowledge Base
Controller fault LED on due to CMOS battery
1,567
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • FAS9000 / AFF A700
  • ONTAP 9
Issue
  • Node reports P3V battery status as "critical low" on SP-LATEST-IPMI:
tag  origin  fld                                     fault reason                                    count  time
2    0x5     /chassis-1/controller-a/coin-1          ipmi P3V_BATT lower non-critical                1      Thu Jan  1 00:02:49 1970
3    0x5     /chassis-1/controller-a/coin-1          ipmi P3V_BATT lower critical                    1      Thu Jan  1 00:02:49 1970
Fault Lights On:
             /chassis-1        2
             /chassis-1/controller-a        2
Sensor Name              State          Current    Critical     Warning     Warning    Critical
                                        Reading       Low         Low         High       High
P3V Batt                 critlow            0 mV     2100 mV     2200 mV     3400 mV     3500 mV
  • Coin cell reports FRU LED is lit
FRU LEDs status
FRU LED ID 01 = PCM FAULT LED
FRU LED ID 03 = SYS FAULT LED
FRU LED ID 41 = Coin Cell FAULT LED
FRU LED ID 1 is on
FRU LED ID 3 is on
FRU LED ID 41 is on
  • Node reports Real Time Clock (RTC ) battery as dangerously low
[?] env_mgr: monitor.rtcLowPower:error]: Real-time clock battery is dangerously low. Replace it at the next available maintenance window.
New to NetApp?
