NetApp Knowledge Base
Controller Fault LED 'ON' and "Sensor 234 Fault" is reported on NV Battery
1,748
Visibility:
Votes:
2
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • AFF A300 / FAS8200
  • AFF A800
  • AFF A320
  • Controller LED on
Issue
  • Controller fault LED is on and the NV Battery is reporting a Sensor 234 Fault.
  • system controller service-event show -instance
Cluster::> system controller service-event show -instance
            Node: FAS-01
Service Event ID: 1
     Description: Sensor 234 Fault
       Timestamp: Sat Jul 23 12:00:13 2022
  • SP log shows Bat_Lrn_Active start asserted at the same time:
Record 328: Sat Jul 23 12:00:13 2022 [IPMI.notice]: 6701 | 02 | EVT: 0301ffff | Bat_Lrn_Active | Assertion Event, "State Asserted"
Record 329: Sat Jul 23 18:47:41 2022 [IPMI.notice]: 6801 | 02 | EVT: 0300ffff | Bat_Lrn_Active | Assertion Event, "State Deasserted"
New to NetApp?
