NetApp Knowledge Base
Controller attention LED on with Set by Expander
3,202
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2720
  • FAS2750
Issue
  • Controller attention LED on.
  • Set by Expander can be found in the following command output.
Example:
FRU LEDs status
FRU LED ID 1  = BMC Locate LED
FRU LED ID 2  = BMC System LED
FRU LED ID 3  = BMC Controller Attention LED
FRU LED ID 4  = BMC Controller Active LED
FRU LED ID 5  = BMC SAS Port A Attention LED
FRU LED ID 6  = BMC SAS Port B Attention LED
FRU LED ID 7  = BMC CNA Port 1 Attention LED
FRU LED ID 8  = BMC CNA Port 2 Attention LED
FRU LED ID 9  = BMC CNA Port 3 Attention LED
FRU LED ID 10 = BMC CNA Port 4 Attention LED
FRU LED ID 11 = BMC 10G Port 1 Attention LED
FRU LED ID 12 = BMC 10G Port 2 Attention LED
FRU LED ID 13 = BMC DIMM Slot 1 Attention LED
FRU LED ID 14 = BMC DIMM Slot 2 Attention LED
FRU LED ID 15 = BMC NVMEM 1 Attention LED
FRU LED ID 16 = BMC BOOT DISK Attention LED
FRU LED ID 17 = BMC NV BATTERY Attention LED
FRU LED ID 18 = BMC Coin Cell Attention LED
FRU LED ID 1 is off
FRU LED ID 2 is on. Set by Expander
FRU LED ID 3 is off
FRU LED ID 4 is off
FRU LED ID 5 is off
FRU LED ID 6 is off
FRU LED ID 7 is off
FRU LED ID 8 is off
FRU LED ID 9 is off
FRU LED ID 10 is off
FRU LED ID 11 is off
FRU LED ID 12 is off
FRU LED ID 13 is off
FRU LED ID 14 is off
FRU LED ID 15 is off
FRU LED ID 16 is off
FRU LED ID 17 is off
FRU LED ID 18 is off
  • The issue can not be resolved by rebooting BMC.
  • The issue can not be resolved by running system fru led set <ID> off command.
BMC>priv set diag
BMC*>system fru led set <ID> off
New to NetApp?
