NetApp Knowledge Base
Cluster switch monitoring issue
599
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • FAS/AFF Systems
  • Cluster switches
Issue
  • The following system health alerts are being reported: SwitchIslIfDownWarn_Alert, SwitchUnreachable_Alert, and UnsupportedSwitch_Alert.
Cluster1::*> system health alert show
    Node: Cluster1-01
        Alert ID: SwitchUnreachable_Alert
        Resource: Old_Switch(FXXXXXXK4)
        Severity: Major
        Indication Time: Thu Feb 27 10:49:10 2025
        Suppress: false
        Acknowledge: false
        Probable Cause: The ethernet switch's IP address is not reachable from
                     the local node.
        Possible Effect: Monitoring of the switch and log collection will not
                     function.
        Corrective Actions: Ensure that the IP address is reachable or specify the
                     correct reachable IP address.
  • The alerts are being reported for an old switch configuration that is neither in use nor visible in the cluster.
Cluster1::*> system switch ethernet show
Switch                      Type               Address          Model
Switch1(FXXXXXXJH)            cluster-network    10.XXX.XX.48    N9K-C9336C-FX2
     Serial Number: FXXXXXXJH
      Is Monitored: true
            Reason: None
  Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                    10.2(5)
    Version Source: CDP/ISDP
Switch2(FXXXXXXK4)          cluster-network    10.XXX.XX.47    N9K-C9336C-FX2
     Serial Number: FXXXXXXK4
      Is Monitored: true
            Reason: None
                    10.2(5)
    Version Source: SNMP
2 entries were displayed.
  • The old switch mentioned in the alerts was previously in use and was later deleted and added back to CSHM with a new IP address.
New to NetApp?
