NetApp Knowledge Base
Chassis power is degraded: P1.2V Standby is critical
1,277
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2720
  • FAS2750
  • Baseboard Management Controller
Issue
  • Hourly EMS alert:
Example:
Time Node Severity Event
5/20/2021 23:14:59 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 22:14:58 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 21:14:58 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 20:14:57 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 19:14:56 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 18:14:55 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 17:14:54 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 16:14:53 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
  • Platform sensors output:
Example:
Node Sensor                 State Value/Units Crit-Low Warn-Low Warn-Hi Crit-Hi
node-01
     PVCCIN CPU            normal
                                     1785 mV      1249     1501    1900    2005
     P5V STBY              normal
                                     4966 mV      4264     4368    5694    5824
     P5V                   normal
                                     5070 mV      4264     4368    5694    5824
     PVDDQ DDR4 AB         normal
                                     1221 mV      1086     1100    1299    1320
     P1.2V Standby
                         crit-low
                                        0 mV      1086     1100    1299    1398
Or
Sensor Name              State          Current    Critical     Warning     Warning    Critical
                                        Reading       Low         Low         High       High
P1.2V Standby            crithigh        1576 mV     1086 mV     1100 mV     1299 mV     1398 mV
  • The issue remains after BMC reboot.
New to NetApp?
