NetApp Knowledge Base
CHASSIS FAN FRU FAILED on AFF A400, C400, FAS8300 , FAS8700
497
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • AFF A400 , C400
  • FAS8300, FAS8700
  • FAN FRU
Issue
  • The following error is reported in EMS
Dec 06 17:27:00 [node02:monitor.globalStatus.critical:EMERGENCY]: There are no enough spare disks. Assign unowned disks. One fan has failed: SysFan4 F2.
Dec 06 17:33:00 [node02:monitor.globalStatus.critical:EMERGENCY]: There are no enough spare disks.  One fan has failed: SysFan4 F2.
Wed Dec 07 13:31:38 +0900 [node02: notifyd: asup.post.drop:error]: AutoSupport message (HA Group Notification from iscsi-vc054-swn-02 (CHASSIS FAN FRU FAILED: Fan4_2) ERROR) was not posted to NetApp. The system will drop the message.
  • The sensor status for one or both fans is "BAD".
SysFan4 F1    discrete    normal            normal    GOOD
SysFan4 F2    discrete    fault            normal    BAD
New to NetApp?
