NetApp Knowledge Base
Attention amber LED ON in IOM Module
899
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
DS212C
Issue
  • Attention amber LED ON in IOM Module
  • IOM status is CRITICAL and All PSU states are displayted as NOT INSTALLED in storage fault show
Enclosure Status: critical
Channel: 0a
Shelf: 33
Shelf Type: DS212-12
Product Serial Number: SHJSG2216000136
Module Type: IOM12
Power Supplies:
Element Status Status Bytes Status Descriptions
1: NOT INSTALLED 05,00,00,20
2: NOT INSTALLED 05,00,00,20
Fans:
3: NOT INSTALLED 05,00,00,20
4: NOT INSTALLED 05,00,00,20
Enclosure:
1: OK 01,00,02,00 FAIL
Vendor Unique Element 83-IOM12: (SAS)
1 [IOM12 A] : CRITICAL 02,00,00,24 RESERVED, RESERVED
2 [IOM12 B] : OK 01,08,00,20 MASTER, RESERVED
New to NetApp?
