NetApp Knowledge Base
Amber LED on disk
5,326
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • DS224C
  • FAS2650
  • FAS2750
Issue
  • The light of disk is amber, but there is no error reported by ONTAP
  • storage show fault command returns no faults
::> system node run -node  Node-01 -command storage show fault
No faults found in storage subsystem
  • Verbose output of the same command shows the disk as having been bypassed by both IOMs
system node run -node Node-01 -command storage show fault -v
Node: Node-01
Enclosure Status: non-critical
Channel: 0a
Shelf: 0
Shelf Type: DS224-12
Product Serial Number: SHFHUXXXXXXXXXX
Module Type: IOM12E
Disk Elements:
Element Status                  Status Bytes  Status Descriptions
0 [Bay  0]: OK                    01,00,00,00
1 [Bay  1]: OK                    01,01,00,00
2 [Bay  2]: OK                    01,02,00,00
3 [Bay  3]: NONCRITICAL           03,0A,20,08   ENCLOSURE BYPASSED A, BYPASSED A
New to NetApp?
