NetApp Knowledge Base
Aggregate reconstruction occurs during head swap, Leaving old system ID
359
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • Head swap from AFF A800 to AFF A90
  • ONTAP 9
Issue
  • During the head swap of the controller, aggregate reconstruction occurs, and disks are missing.
  • When checking with storage disk show, the affected disks still have the old owner ID.
cluster::*> storage disk show -nodelist node-02 -fields owner-id
disk    owner-id
 - snip -
1.0.32  333333333
1.0.33  444444444
1.0.34  444444444
1.0.35  444444444
1.0.36  333333333
1.0.37  333333333
1.0.38  222222222
1.0.39  333333333
1.0.40  333333333
 - snip -
  • system controller replace show is paused on error.
cluster::*> system controller replace show
Node             Status                   Error-Action
node-01 Completed
node-02 Paused-on-error          Aggregate reconstruction in progress.
                                          Ensure that no aggregate reconstruction is going on during controller replacement operation
  • system controller replace show-details shows Aggr Reconstruction paused on error with Aggregate reconstruction in progress.
cluster::*> system controller replace show-details
Task Phase       Node            Task Name            Operation-State
Precheck         node-01
                                 Cluster Health Check  Completed
                                 MCC Cluster Check     Completed
                                 DR operation state    Completed
                                 check
 - snip -
Postcheck       node-02
                                 Verify Details        Completed
                                 Cluster Quorum Check  Completed
                                 Data LIF Status Check Completed
                                 Aggr Reconstruction   Paused-on-error
                                 Check
                                                       Aggregate
                                                       reconstruction in
                                                       progress.
New to NetApp?
