NetApp Knowledge Base
After reboot node is down, SP accessible but no console output due to power
1,247
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • AFF Systems
  • FAS Systems
Issue
  • Node was rebooted for maintence and then unable to boot back up.
  • When connected via console cable SP is accessible and system power status is off. When turned on and moved to the console output the node shows the copyright message then stops.
  • If system power status is checked again it reports as off.
    SP> System power status
    Power status: off
    SP> system power on
    SP> system console
    Copyright 2021 American Megatrends, Inc.
    (CTRL + D to flip back to SP)
    Power status: off
New to NetApp?
