NetApp Knowledge Base
ANDU paused with takeover not possible due to scsi blade going offline
724
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • AFF-A700
Issue
  • ANDU paused with takeover not possible due to SCSI blade going offline.
Cluster::*> storage failover show
 (storage failover show)
                             Takeover
Node           Partner        Possible State Description
node-1
                              false    Connected to node-2,
              node-2                   Partial giveback, Takeover is not
                                       possible: The version of software
                                       running on each node of the SFO pair
                                       is incompatible, NVRAM log not
                                       synchronized
node-2
                              false    Connected to  node-1.
              node-1                   Waiting for cluster applications to come online
                                       on the local node. Offline
                                       applications: scsi blade. Takeover
                                       is not possible: The version of
                                       software running on each node of the
                                       SFO pair is incompatible, NVRAM log
                                       not synchronized
  • After ONTAP upgrade complete on node-2, The FC adapters on node-2 were made offline by the system.
        slot 2: Fibre Channel Target Host Adapter 2a
                (Emulex LPe32000 (LPe32004) rev. 0, <OFFLINED BY SYSTEM>)
                Firmware rev:      0.0.0.0
                Host Port Addr:    000000
                FC Nodename:       50:0a:09:80:xx:xx:xx:xx (500a0980xxxxxxxx)
                FC Portname:       50:0a:09:85:xx:xx:xx:xx (500a0985xxxxxxxx)
                Connection:        No link
                Switch Port:       Unknown
        slot 2: Fibre Channel Target Host Adapter 2b
                FC Portname:       50:0a:09:86:xx:xx:xx:xx (500a0986xxxxxxxx)
                Connection:        No link
New to NetApp?
