NetApp Knowledge Base
Access to System Manager starts to fail by "ERR_SSL_KEY_USAGE_INCOMPATIBLE"
17,603
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
  • ONTAP System Manager
Issue
  • Access to System Manager starts to fail by ERR_SSL_KEY_USAGE_INCOMPATIBLE even though there is no change on ONTAP.
The webpage at https://<CLUSTER_MANAGEMENT_IP>/sysmgr/v4/ might be temporarily down or it may have moved permanently to a new web address.
  • Browsers may report
    • ERR_CERT_AUTHORITY_INVALID
    • ERR_SSL_KEY_USAGE_INCOMPATIBLE
  • ONTAP has not been upgraded since the SSL certificate was generated.
New to NetApp?
