How to convert a target volume created by SANtricity's volume copy from read-only to read/write?
Applies to
- E-Series
- Copy volume
- A target volume created using SANtricity's volume copy function remains with the "volume copy target" attribute even after the copy is complete.
- By default, it is read-only.
- By removing this attribute, the volume can be used as a normal read/write volume.
- To remove the "volume copy target" attribute from a target volume, it needs to remove volume copy relationship by SANtricity management GUI interface or CLI (SMcli).
