NetApp Knowledge Base
E-Series Power supply failed - AutoSupport Message
1,552
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
NetApp E-Series
Event Summary
  • An AutoSupport messages is generated with title:
E-Series Notification (Power supply failed) CRITICAL
  • An associated case is generated with symptom:
EVOLEN:E-Series Notification from Unnamed (Power supply failed) CRITICAL
Validate
  1. Login to SANtricity Storage Manager or SANtricity System Manager
  2. Confirm SANtricity reports one of more of the following error messages in the Recovery GURU:
    1. Failure Entry 1: SUPPORT_CRU_NOINPUT-Recovery Failure Type Code: 97
      Storage array: xyz
      Component reporting problem: Power supply canister (Right)
      Status: No power input
  3. Confirm from the Hardware tab that the power supply shows as failed
    1. Example:
             Power Supplies Detected:  2
                     Power supply status:  Optimal
                     Part number:          114-00148+D0
                     Serial number:        111111111111111
                     Vendor:               DELTA
                     Date of manufacture:  Not Available
                     Power supply status:  Failed
                     Serial number:        222222222222222
                     Vendor:               DELTA
Resolution
  • Ensure there are no issues with the power source feeding the PSU (power supply unit).
  • Contact NetApp Technical Support as this will likely require a power supply replacement
  • If AutoSupport is enabled, this event should have already created a technical support case
