NetApp Knowledge Base
How to run combined major upgrade and hotfix script for StorageGRID
13,272
Visibility:
Votes:
17
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
  • StorageGRID upgrades
    • 11.6.0.x
    • 11.5.0.2+ to 11.6.0.x
    • 11.4.0.7+ to 11.5.0.x
    • 11.3.0.13+ to 11.4.0.x
  • Check the system's condition has been completed in advance.
  • This KB describes a single procedure for applying a hotfix while you upgrade StorageGRID software to a new version.
  • You can use this procedure instead of applying a hotfix as a separate step after completing the StorageGRID software upgrade.
  • 11.7.x and above allows you to upload both files from the GUI.
New to NetApp?
