StorageGRID reports Alert Node network reception frame error
- 2,242
- Visibility:
- Public
- Votes:
- 0
- Category:
- storagegrid
- Specialty:
- sgrid
- Last Updated:
- 4/11/2025, 1:09:53 PM
Applies to
NetApp StorageGRID Appliances
Issue
- StorageGRID reports Alert
- Node network reception frame error
- Node network connectivity error
- Ensure to verify and follow: Frame errors incrementing against StorageGRID node after network maintenance
- In Overview page, scroll down to the network Receive statistic table.
- Find out the affected NIC by matching the amount of Frames of each NIC with Receive Errors at the bottom of the table.
- From Support > Grid Topology > SSM > Resources, alarm reported NRER and/ or NTER alarms.
- Ethtool command shows plenty of received CRC errors:
Command: ethtool --statistics hic2
rx_crc_errors: 102638016
