NetApp Knowledge Base
StorageGRID Low Audit Log Capacity - AutoSupport Message
3,510
Visibility:
Votes:
1
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
Event Summary
StorageGRID reports LowAuditLogCapacity indicating the space available for the audit log filesystem is low.
Alert description:
Storage volume needs attention
A storage volume is offline and needs attention.
Recommended actions
1. Resolve other storage-related alerts that might have caused this alert.
2. If this alert persists, contact technical support.
Node    <nodename>
Site   <sitename>
Severity    Critical
Time triggered    <date>
Device    /dev/sdc
Job    miscd
Mountpoint    /var/local/audit/export
Validate
  1. Login to the Primary Admin node with SSH
  2. Run df -h
  3. Verify space usage under /var/local/audit/export
Resolution
There are several resolutions to be considered:
Additional Information
Add your text here.
