NetApp Knowledge Base
How to troubleshoot StorageGRID unable to communicate with node (NDDOWN)
7,269
Visibility:
Votes:
2
Category:
storagegrid
Specialty:
sgrid
Last Updated:
Applies to
  • NetApp StorageGRID
  • NetApp StorageGRID Appliances
  • NetApp StorageGRID VMware based nodes
  • NetApp StorageGRID Bare-metal based nodes
This article helps in identifying the cause of a StorageGRID node down. Multiple causes may cause a StorageGRID node to be in a disconnected state, such as:
  • Maintenance operations
  • Network connectivity issues (GRID Network)
    • The GRID network is used for inter node communication.
    • This is the connection between the node to the primary admin node.
  • Hardware issues
  • File system corruption
  • Resource issues (such as CPU, memory or disk). A common symptom of resource issues is sluggish/slow responses within the systems shell/cli/ssh.
  • Decommission
StorageGRID may report the following errors:
  • StorageGRID node(s) appear next to a blue icon StorageGRID node(s) (Disconnected – Unknown) in the Grid Manager
  • StorageGRID reports the Unable to communicate with Node alert
  • Unexpected node reboot if the node came back online on its own
  • StorageGRID reports the NDDOWN legacy alarm
  • If AutoSupport is enabled, it will open a NDDOWN AutoSupport incident:
    • CSTARS:StorageGRID Notification from <serial number> (NODE_DOWN-CRITICAL) ERROR
New to NetApp?
