NetApp Knowledge Base
UCS SAN Boot Reference Documentation
3,044
Visibility:
Votes:
7
Category:
flexpod-with-infrastructure-automation
Specialty:
san
Last Updated:
Applies to
  •  SAN
  •  SAN Protocol
Connectivity related issues with Cisco UCS products can often be resolved by validating the configuration against the initial setup documentation. Below you will find documents for configuring Cisco UCS with NetApp storage. While most of the documentation is targeted at the Cisco/NetApp partnership program called Flexpod, it is important to note that these documents follow best practices put in place by both NetApp and Cisco.
If you are unable to find a guide that matches the your current configuration, there are additional guides available at  Cisco Flexpod Validated Designs as well as NetApp Validated Designs.
